"Big" cams - vacuum pump or vacuum canister?
Old 07-15-2005, 04:01 PM
  #31
Zero_to_69's Avatar
Re: "Big" cams - vacuum pump or vacuum canister?
What could be the problem? I'm thinking and hoping it may be something stupid like the hose going into the brake booster not sealing up tightly enough. Is that a possibility, or am I just on crack?
A vacuum leak will certainly kill the brake assist.
How about cam phasing, did you dail-in the camshaft?
Zero_to_69 is offline
Old 09-03-2005, 01:54 PM
  #32
Mullet Z28's Avatar
OK, LT1 Edit says I'm pulling 43 Kpa at idle. If I did the math correctly, that's 12.7 inches of vacuum. Should be plenty, right?
I pulled off the hose that goes from the manifold to the brake booster after I shut the motor off, and the "swoosh" I heard indicates that there's at least some vacuum in there, although I have no idea how much. Any idea what the problem is? I'm getting absolutely no vacuum assist at all when I step on the pedal.
Mullet Z28 is offline
Old 09-03-2005, 04:10 PM
  #33
Zero_to_69's Avatar
If LT1 edit is anything like AutoTap, you'll need to find out atmospheric
pressure at your elevation, then subtract the value found in LT1 edit to
get your gauge reading.
If you've already done that, then 12 in./hg. is sufficient to assist with brakes.
Old 09-03-2005, 07:16 PM
  #34
Mullet Z28's Avatar
According to my weather station, the dry barometric pressure is 28.6 inches. That means I have close to 16 inches of vacuum, right?
Old 09-04-2005, 02:01 PM
  #35
Zero_to_69's Avatar
Yes. You can also try getting a reading from LT1 Edit by scanning the MAP
sensor without the engine running (instead of using a weather station).
HectorM52
07-30-2017 11:46 AM
DirtyDaveW
03-15-2015 07:01 PM
Queens94z28
12-20-2014 09:11 PM
blac94Z
11-28-2014 01:53 PM
squarehead
11-21-2014 08:02 PM
Quick Reply: "Big" cams - vacuum pump or vacuum canister?
