"Big" cams - vacuum pump or vacuum canister?
#16
Re: "Big" cams - vacuum pump or vacuum canister?
Hey Jim,
Yeah I'm seeing more and more sbc/rx7 swaps all the time. There was a black one (maybe 93') on LS1.com for sale. Guy's in Florida and this car has an LS1 in it turning low 11's or so. Was asking 27k which I didn't think was too bad when you conider the sweat spent in putting one of these together yourself.
What are you rx7 swappers using for rearends in these builds?
-Mindgame
-Mindgame
#17
Uh oh..... Mindgame has a idea for a new toy...
Why not go with a I6 of some sort here? Make something along the lines of the TVR 350R..... yummy.
I don't know if a 4200 Vortec with a turbo on it would fit, maybe if you angle it on it's side some, al la E46 M3
Bret
Bret
#19
any of the online parts depots will have them.I got mine from GMPP as i have alot of GMPP stuff so it matches, and i have friend so i dont have to pay their big $.
I personally prefer to use a local friends or supporting vendors on the board if i can so i dont pay for Jeggies pro stock adventures.
#20
1. Use a Hinson Supercars torque arm and stock differential housing (with an upgraded KAAZ differential and 300M axles) until it grenades. The limitation is 3.90:1 is the lowest gear set you'll find, and the other options are 4.10:1, 4.33:1, and 4.70:1. That's it.
2. Back-half the car and put whatever you want in the back.
3. My '03-'04 Cobra 8.8" IRS setup with hybrid 300M chromemoly axles which retains all the stock suspension, brakes, wheels and tires, and maintains the stock handling of the car (the setup is about 5-6 lbs. heavier overall). No torque arm required, all the gears you can eat.
http://home.gci.net/~jimlab/images/Cobra/PC080013.jpg
http://home.gci.net/~jimlab/images/Cobra/PC080019.jpg
#21
BTW, anyone know if you can replace the "steam" hardline that connects the rear of the cylinder heads with NPT/AN fittings and hose? I asked in LT1 land, and of course no one had a clue.
I haven't been able to determine what the thread size of the 2 banjo bolts that go through the "blocks" in the hardline into the heads is yet.
#22
Yeah wish I had a pic of what I do.....
I just get the hard line and cut the part that joins the heads and put a AN line in there..... 4AN If I remember right. Keeps everything else and works awesome.
Bret
Bret
#23
#24
I keep the Banjo's because that line is more of a vent line for air bubbles than a line for coolant to run thru. Maintains the flow thru the back of the heads that the factory wanted.
Bret
Bret
#25
I cut the hardline in half and connect them with a rubber tube and a couple of hose clamps. I think that may not be advanced tech enough for some guys .
Ryan
Ryan
#26
Hmm....I have a 245/250ish cam with .620 lift on a 112 LSA. It's in a 12.0:1 383. Based on what I'm reading here, I shouldn't have a vacuum problem, but my brakes think otherwise. I'm getting no vacuum assist whatsoever when I step on the pedal.
What could be the problem? I'm thinking and hoping it may be something stupid like the hose going into the brake booster not sealing up tightly enough. Is that a possibility, or am I just on crack?
#27
Rich
#28
Originally Posted by rskrause
How much vacuum is it pulling? If you don't have a gauge, you need one.
Rich
Rich
#29
I used a braided stainless line in back to replace the hard line. The threads are .25" straight pipe.
#30
