64cc VS 70cc Combustion Chamber - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 12-25-2002, 02:00 AM   #1
Question 64cc VS 70cc Combustion Chamber
i am looking to buy new je pistons and a set of edelbrock victor jr cylinder heads but i am not sure whether i want 64cc or 70cc cylinder heads
i dont want to go any higher than 10.1 CR and je recommends me going with a 70cc combustion chamber with this piston(10.3:1) if i dont want to go above 10.1
BUT
what will i experience any performance difference between a 64cc combustion camber and a 70cc combustion chamber?
99huggerorangeZ is offline   Reply With Quote
Old 12-27-2002, 11:21 AM   #2
Mindgame's Avatar
Just comes down to shrouding. On a standard angle valve centerline you will probably have better deshroud around the intake valve with the larger chamber. Then again, it all depends on where the extra volume was added? Is the chamber just deeper or what? I don't have an answer to that question but that might be something to ask before you buy. Don't know much about the Vic Jr's.
Best of luck.
-Mindgame
Mindgame is offline   Reply With Quote
Old 12-29-2002, 11:24 AM   #3
Post
There are alot of specifics that need to be answered like the ones in Mindgame's post.
But the general rule of thumb is ...the higher the compression; the higher the HP/TQ output. 1 point of compression = 4% of power.
Ex: 10:1 compression engine putting out 400HP
this same engine at 9:1 would be putting out approximately 16 HP less!
Heavy
HeavyChevySS is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
1994 Camaro Z-28, 850hp, Supercharged 396 w/NOS, 9.5@143 RUENUF Cars For Sale 6 03-13-2016 03:37 PM
94 Z28 Automatic transmission - engine stall - No codes present Nayr LT1 Based Engine Tech 3 09-05-2015 06:12 PM
Beautiful 98SS 427 professionally moded realistyc Cars For Sale 4 07-28-2015 07:32 PM
The RX Oil Separating Catch Can System RX Speed Works Supporting Vendor Group Purchases and Sales 0 07-24-2015 02:25 PM
Combustion chamber size Duke79Zer Advanced Tech 8 09-23-2002 05:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
