Cam question (Nitrous related)
Old 12-28-2002, 10:35 AM
MichiganSkip's Avatar
What's the theory on the "nitrous grinds"? I'm thinking of changing cams and want one that will optimize my nitrous set-up. I'm not too concerned about N/A perfomance as it's also a cruiser.
What specs should I look for on a "nitrous " cam?
Skip
MichiganSkip is offline
Old 12-28-2002, 12:28 PM
SStrokerAce's Avatar
How much Nitrous?
Mostly if it's a cruiser I would look at a cam with a higher LSA number. Usually that and a longer exhaust duration help.
There are also some tricks that racers do with the lobes on Nitrous Grind cams. Mostly it's shutting the valve extremly fast.
Bret
SStrokerAce is offline
Old 12-29-2002, 06:35 AM
150hp shot. It's got stock heads, A4, PI 3200 and 3.73''s. I e-mailed Comp Cams about a suggestion but got no answer. Would I have to come up with some numbers and then have someone grind a cam to those specs?
Skip
10-31-2016 11:09 AM
MadMav
05-25-2015 09:35 PM
bandit383lt4
12-21-2014 09:12 PM
Lt1son
N2O Tech
11-25-2014 01:52 PM
Black Sunshine/ 00SS
07-17-2002 08:41 PM
Quick Reply: Cam question (Nitrous related)
