zexel-torsen differential anygood?
Old 12-05-2002, 09:45 AM
  #16
Tim Burgess's Avatar
Thanks for the compliments, Willie! As you mentioned, the use of the aluminum cover, or diff girdle, is important for the survival of our 10 bolt axles under heavy load - the diff "girdle" cover gives extra support to the main bearing caps. I bought the TPIS girdle, which comes with studs and nuts to replace the four main bearing bolts - the studs thread all the way to the bottom of the threaded holes for maximum strength & the nuts are torqued to spec. The girdle has two threaded studs which are adjusted to contact the main bearing caps, at their mid point, with a slight amount of pressure, after the cover bolts are torqued to spec - this gives the caps support in the center and prevents deformation under high load conditions - like when launching with DOT slicks for 1.6 sec 60' times. For about $100, it's good insurance. Can't remember which one you bought, Willie, but I know it's not from TPIS - so there are others available now - unlike back in the mid 90's.
Tim Burgess is offline
Old 12-05-2002, 12:47 PM
  #17
Jim85IROC's Avatar
Originally posted by Willie
....unless you upgrade to 28-spline axles!! But don't go with GM's because of the cost. They are about $300 each. Instead, why not go with Moser's, which are about 30 percent stronger than GM's and they run for about $240 per pair!!!
So the second choice is go with the $99 Torsen and $240 Moser's for a total of ~$350. In my opinion, the extra $50 is worth the cost. FYI, the Moser axles work with both drum and disc rears.
Willie
This is the route I chose, based almost 100% on Willie's opinion. I researched it, talked to people including Willie, and became convinced that this was the best option for me right now. So far I'm quite happy, although I haven't got enough traction for anything to break yet. The Moser axles are a VERY well made, very high quality axle. I'm very impressed with them.
Jim85IROC is offline
Old 12-05-2002, 11:57 PM
  #18
STAYBG's Avatar
well i guess theres no need for this reply anymore. i just found out the differential i got was the right one.i didnt know if it was for the 3:23 and up ratio.but for anyone that whats to know how you can tell.stick a 3:08 and down ratio diff. and a 3:23 and up ratio diff. next to each other and the 3:08 and down were the ring sits to the diff. will be lower than the diff. that accepts the 3:23 and up ratio. i hope this makes sense to you guys.
STAYBG is offline
Henson071
09-18-2015 04:01 PM
95z_28_camaro_4_Ivan
08-25-2015 03:59 PM
KevinAce
V6 Tech
12
02-23-2003 03:28 PM
jimlab
Advanced Tech
14
10-20-2002 04:02 PM
Quick Reply: zexel-torsen differential anygood?
