TPI stumble at WOT
Old 10-13-2003, 03:08 AM
stk350's Avatar
Question TPI stumble at WOT
When I first start my car in the morning, it runs fine. But after about a minnute or two, the car stumbles at WOT. 1987 IROC tpi 350. I have no idea. I drove the car about 100mi on a trip and when I got back is when it started hapening. Come to find out, I had 2 burn plug wires. Replaced them. Is it possible that I have more damaged wires and when the heat hits them (after about 1-2 min) that they would cause a miss?
stk350 is offline
Old 10-13-2003, 03:12 AM
DarthIROC's Avatar
Location: Teeter-tottering between Brilliance and Insanity
If two wires were burnt then the plugs may have been sitting down in the gas and not firing right, they may be fouled out. Try replacing the plugs, and might as well buy a new cap and rotor too.
DarthIROC is offline
Old 10-13-2003, 03:22 AM
stk350's Avatar
Nah, cap and rotor are brand new. Good call on the plugs though. I'll have to look at the plugs tomorrow. Makes sence. I rod around with the miss (bad wires) for a while.
stk350 is offline
Old 10-13-2003, 07:50 AM
DrDUKE's Avatar
You could aslo check your TPS, also your O2 sensors could have gone out.
DrDUKE is offline
Old 10-16-2003, 12:16 AM
stk350's Avatar
You know what! Now that I think of it, you can foul a o2 sensor with a miss just like a spark plug right? I just replaced the 02 a few months ago but that could be the problem.
stk350 is offline
Old 10-16-2003, 09:29 AM
aklim's Avatar
Sure it could. What has the O2 sensor got to do with WOT? The ECM ignores the O2 sensor at WOT so you might have other problems.
aklim is offline
Old 10-16-2003, 01:10 PM
stk350's Avatar
really. intresting. I guess I'll just start throwing parts at it.
stk350 is offline
Old 10-16-2003, 05:22 PM
DrDUKE's Avatar
Hmm did not know that.
DrDUKE is offline
Old 10-24-2003, 07:56 PM
stk350's Avatar
OK, turned out to be the ignition coil. But I still get a MAF ses code. Says that voltage to high. Put in another one, reads voltage to low. WTF. Also, with the voltage low MAF sensors, the car wont stay running untill the ses light comes on. Any suggestions
Steve
stk350 is offline
G-BODYT56
01-14-2022 11:14 PM
93 RedBird
11-15-2015 08:24 AM
PopoFormula
10-12-2015 04:19 PM
SEOJustin
09-24-2015 04:39 PM
tommalcolm
09-11-2015 03:39 PM
Quick Reply: TPI stumble at WOT
