Torque Arm Placement ON FORD 9 INCH???
I am going to have to go with a FORD 9 inch because I will be making 550 - 600 rwhp and in doing so I won't have aplace to bolt on my nice new MAC torque arm relocation kit. WHat do guys do about this dilemma?? I would like to put this piece of equipment on my car but what do you do when you go Ford 9 Thanks guys.
you can use a moser or strange 12 bolt they dont have to have the braket but you do have to pay out a few more $$$$ plus if you plan on using this as a street cars I have heard the posi in the 9" is not as good as the 12 bolts something about only having clutch packs on one side...I know a guy who has a 9" and has the braket it is all from moser but it has a locker he also runs the stock tq. arm on a 1.46 60 ft
91 Camaro SS
305 tbi edelbrock intake &strut brace crane compucam march underdrive pulleys ads superchip k&n open air cleaner mac headers & subframe con. 3"flowmaster ascd ss hood and gm ss rims 6 speed star spec stage3 carbon fiber clutch Sphon suspension eibach sport line springs bilsten shocks and struts,mosser 12 bolt 4.11, 400+hp lt1 in the build up waiting to get the heads back. carbua targa rs seats ,pics http://www.ofoto.com/I.jsp?m=72211043303&n=849405583
91 Camaro SS
I have a 9" Ford rear in two third gens. Both are Moser units- http://www.moserengineering.com/mose...ts.asp?CatID=8
I use a Detroit locker and 3.73 gear. Both put over 600 HP to the wheels-no issues.
You can order a complete bolt in unit with torque arm mount, etc
90 IROC,394 ci,vortech,SR intake, Accel DFI, MSD 72lb. injectors,Accel injector cntrl,Tremec TKO, 9" Ford,NX 150 HP shot, Spohn adj ctrl arms-sway bars-race tqe arm-,Ground Control coil overs & camber plates,EDL tower brace, roll bar,Kirkey seat
my pics
my pics
I assumed he already had the 9" and was looking to adapt it to a third-gen considering pretty much all bolt in application 12 bolt and 9" rears come set up with the torque arm mounting points. If you are indeed fitting a home built 9" into your car(wich many people do) call up moser or strange and get the torque arm mounting bracket for your application. They do in fact sell the bracket that you can attach to I think any 9" housing. If you are talking about buying a complete bolt in unit then just order it up as a complete bolt in.
I think Currie is the only one that sells the mounting bracket seperate. You need to weld mounts onto the housing. The bracket bolts to the mounts and the torque arm bolts to the bracket.
The bracket kit was around $150 last time I checked.
I use a spool in my 9" so I don't worry about clutches.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.646
Member of the Calgary Drag Racing Association
461 big block
Best 60 foot: 1.646
carguyshu
01-22-2017 11:19 AM
KYWes
04-24-2015 09:17 AM
