Temp guage
#17
Re: Temp guage
When running the volt meter from ground to the sensor the ohms reading showed up perfectly in accordance with the shbox chart intermittently. I've ordered the sensor and some shrink wrap and will be replacing the pigtail in the next few days. I really appreciate your assistance!
Thanks so much
Thanks so much
#18
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Temp guage
P.E.D. means Packard Electrical Division, now a part of Delphi Automotive Systems, which makes the connectors for GM cars.
#19
Re: Temp guage - SOLVED
a new harness connector has solved this issue.
Next up.. the annoying Airbag light wont go off now... I recently changed all my interior and gauge bulbs to LEDs.. maybe that is the issue.
I will search the forums for more information on this.
Thanks for the the help with this temp gauge issue that is now SOLVED
#20
Re: Temp guage
Since the airbag problem appears to be on your 4th Gen 93, I would recommend you start a new thread on the "General 67-02 F-Body Tech" forum. Not likely to get a lot of help on the 3rd Gen engine tech forum.
#21
