Temp guage
Old 10-01-2015, 05:33 PM
  #16
Re: Temp guage
You indicated you have 12V at the sensor connector. Is that the connector you feel is the problem? Is it an intermittent problem?
Injuneer is offline
Old 10-01-2015, 07:53 PM
  #17
tritonium's Avatar
Re: Temp guage
When running the volt meter from ground to the sensor the ohms reading showed up perfectly in accordance with the shbox chart intermittently. I've ordered the sensor and some shrink wrap and will be replacing the pigtail in the next few days. I really appreciate your assistance!
Thanks so much
tritonium is offline
Old 10-01-2015, 09:15 PM
  #18
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: Temp guage
Originally Posted by tritonium
There is a small plug under the dash by my feet marked ,PED with a grey and striped black wire not connected to anything . I'm assuming this means pedal..
Thanks again guys !
P.E.D. means Packard Electrical Division, now a part of Delphi Automotive Systems, which makes the connectors for GM cars.
GaryDoug is offline
Old 10-04-2015, 02:55 PM
  #19
tritonium's Avatar
Re: Temp guage - SOLVED
a new harness connector has solved this issue.
Next up.. the annoying Airbag light wont go off now... I recently changed all my interior and gauge bulbs to LEDs.. maybe that is the issue.
I will search the forums for more information on this.
Thanks for the the help with this temp gauge issue that is now SOLVED
Old 10-04-2015, 04:55 PM
  #20
Re: Temp guage
Since the airbag problem appears to be on your 4th Gen 93, I would recommend you start a new thread on the "General 67-02 F-Body Tech" forum. Not likely to get a lot of help on the 3rd Gen engine tech forum.
Injuneer is offline
Old 10-04-2015, 05:10 PM
  #21
tritonium's Avatar
Re: Temp guage
Thanks!
93 RedBird
11-15-2015 08:24 AM
IndyZman
10-22-2015 02:17 PM
Bigtoyz97
09-21-2015 01:44 PM
plattted
9
09-20-2015 11:23 AM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: Temp guage
