need help with ac compressor clutch wiring
i have an 89 iroc 305 tpi and i have a residual ac charge. the problem is that the plug for the ac clutch is inexplicably missing. can someone thell me where the wires for this come from so i can either rewire one in or find the actual plug i have looked for about 10 minutes but i cant find it. its the plug that plugs into the front of the compressor btw.
any help would be appreciated.
Re: need help with ac compressor clutch wiring
Find it yet? Looking for a green and black pair of wires, in a short separate plastic loom running from the big harness at the top front corner of the valve cover. Probably fell down behind the compressor. The overpressure switch on the rear has a green and gray or green/gray stripe wires to it. Different connector though.
i found it but the conector is for a different style of compressor so it wont work. so i have to go to a jy and get the proper connector for my compressor.
stockssn2o
05-25-2015 08:54 AM
