Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 10-12-2010, 11:41 AM   #1
starting project cat that has been sitting
I have an 86 Trans Am with 350, Vette heads, Edelbrock intake, Holly carb and Headmen headers that my son bought years ago as a project car, he put it in my garage and lost interest. It was running when it was parked. I want to get it running and out of the garage.
I changed the oil, pulled 5 of the plugs and squirted a little oil in the cylinders. I can't get the other 3 plugs out without pulling the headers.
The battery is dead, but I have a new marine deep cycle battery with 600 CCA, I hook up with jumper cables with the old battery completely disconnected. The engine will turn over, but only very slowly.
I assume it is just because it has been sitting so long, but want to see if anyone thinks the battery is not strong enough, or there might be any other reasons.
Any suggestions to help me get it running would be appreciated.
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
Al
86 Trans Am, M5, 350 4 bbl, I-H-E, BW 9 bolt posi.
HiG4s is offline   Reply With Quote
Old 10-14-2010, 09:09 PM   #2
Well 600 cca should be more than enough to turn it over. Are you sure the battery your using is fully charged? Maybe try some starting fluid in the carb while cranking it. Also check your wires over well. Mice love those precious num nuns we know as wires.
Dustin
1badeagle is offline   Reply With Quote
Old 10-14-2010, 09:49 PM   #3
Quote:
Dustin
Battery is only 6 months old and on a battery tender. It is not actually turning over fast enough to even try to start it yet, so I haven't put the plugs back in. I need to get a wrench that will allow me to get the plugs out where the header is close. I suppose it could be the starter or starter connections.
__________________
Al
Old 10-15-2010, 12:02 AM   #4
I don't know, maybe put the plugs back in and try to start it slow rolling it may suprise you.
Old 10-15-2010, 03:41 PM   #5
Send a message via Yahoo to BigBadLou
Careful:
1. Marine Deep Cycle batteries are not designed for cranking engines, excessive use for starting will damage them. You don't want to destroy your new expensive marine battery.
2. Jumper cables do not provide good enough connections to transfer the hundreds of cranking amps from the battery to the starter. That's why the engine is turning over very slowly. And the jumper cables will get hot the longer you crank.
At least you know that the engine is turning over, that's a good sign! *thumb up*
I would recommend either putting the marine battery in temporarily (if the cables will mate up but most likely not because marine batteries have commonly different terminals from car batteries) if you just want to start the car.
Or if you have a strong battery charger (with start assist), you can hook it up to the car's battery cables as well (not to the battery) and that might be just enough current to turn the engine over fast enough to start it up.
Otherwise I'd recommend just getting a new car battery. If you want the car actually running to use it, it will need its own battery anyway.
If you already changed the oil, I recommend changing it again after a few days of driving. The new oil will dissolve some of the built up sludge and you don't want that circulating in the engine.
If you want to flush the oil system better, you can do this:
After you drain the oil (warm engine), you can put in two quarts of cheap thin oil (e.g. 5W-20), run the engine for a few minutes, drain the sludge, repeat the procedure with two more quarts. Like I mentioned, don't use expensive oil, you're just flushing the engine.
Then replace the oil filter and refill the engine with 4 fresh quarts.
Hope this helps.
Lou
BigBadLou is offline   Reply With Quote
Old 10-17-2010, 12:46 PM   #6
Thanks Lou,,
The marine battery will not fit, and the battery that is in it is so bad it kills my charger with start boost. So, looks like new battery Monday.
__________________
Al
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
