speedometer conversion
Old 06-08-2004, 04:49 PM
ruffryder8872's Avatar
how can you replace a new 145 mph gauge with the original 85 mph gauge, if anyone knows a website with steps for it, or knows a conversion kit it would be great.
ruffryder8872 is offline
Old 06-08-2004, 07:57 PM
Killaz's Avatar
i was wondering if you will be selling the 145mph gauge. I would like to buy it from you. How much if your selling?
Killaz is offline
Old 06-08-2004, 08:29 PM
i must have worded it wrong, i want to put a new 145 mph gauge instead of the old one, please help, anybody...?
Old 06-09-2004, 06:19 AM
greezemonkey's Avatar
Lightbulb speedo r&r
82 -89 speedo`s all interchange, you can just swap the speedo gauge if you want..no other changes are needed just the speedo you want to use. You can probably find one right here on the parts for sale sec. you need to remove the face plate first (little torax bolts) then remove the 7/32 screws and the 7/16 speed nuts hidden in the "warning lite" section at the bottom around the perimeter, next remove the column lower valance and then unbolt the steering column to lower it down some. Now you can reach behind the speedo and pull the clip toward you( for the cable) as you pull on the instrment head. Once this is on the bench you can unbolt the speedo from behind. here are some I found if ur looking
http://web.camaross.com/forums/showt...145+mph+speedo
another
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
and another
greezemonkey is offline
Old 06-09-2004, 11:49 AM
thank you very much, i was just wondering if there were any mecahnical things i needed to do so taht it would accurately read at the rite mph and rpms when i switched it, i didnt really need to know how to take it out, but thank you for your help
Old 06-09-2004, 11:55 AM
buzz12586's Avatar
Yea I was wondering the same thing, will you have to change speedo gears or anything???
buzz12586 is offline
Old 06-09-2004, 12:39 PM
Not if your speedo is correct now
Old 06-09-2004, 08:58 PM
buzz12586's Avatar
So it will register all the way up to 145 correctly?
Old 06-10-2004, 05:42 AM
Old 06-10-2004, 07:25 AM
Sitting Bull's Avatar
This guy in California also sells the 145 mph gauges.
http://members.***.net/iroczdave1/
Sitting Bull is offline
RUENUF
03-13-2016 03:37 PM
Henson071
09-18-2015 04:01 PM
tdigger9899
09-07-2015 10:56 AM
LazyLemming
08-29-2015 07:36 PM
Quick Reply: speedometer conversion
