Smoke From the Small Tubes Running to the Cylinders
Old 07-18-2004, 09:26 AM
Tom87IROC's Avatar
Finally got my alternator back from the rebuild shop. I had them beef up the rectifiers. Now it is a 150A instead of 105A. Anyway, after my test run around the neighborhood, I noticed a burning oil smell. Under the hood, a small stream of smoke was coming up from the small tube on the driver's side that I believe have something to do with the fuel injection system. Anyone have an idea on what this might be? Are there areas around these parts that leak. We are talking about a 17 year old 5.7L engine here. Any assistance would be appreciated.
Tom87IROC is offline
Old 07-18-2004, 11:47 AM
PyRo9862's Avatar
Well there are lots of tubes
The one going into the valve cover? PCV valve
PyRo9862 is offline
Old 07-18-2004, 10:24 PM
IROC-T's Avatar
Re: Smoke From the Small Tubes Running to the Cylinders
I had this a couple of years ago on the passenger side where you can't see very well,but to make a long story short it was the valve cover gaskets. They both sides had split and would leak a drop or two every couple of minutes and smoke ,you could not tell where it was comming from.
IROC-T is offline
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
z28projects4ever
9
07-16-2002 07:48 PM
Quick Reply: Smoke From the Small Tubes Running to the Cylinders
