smog and AIR pump question
I bought a set of hooker headers(2460) for my 91 camaro 5.7 tpi, the headers do NOT have the AIR pump lines to it.
can i take off the AIR pump and the lines without it giving me a check engine light?
i would like to take off as much emissions stuff as i can without losing my A/C or pulling a check engine light.
does anyone have experience with this?
Yes,
you can take the air pump off and it won't throw any codes. Once your car goes into closed loop, it doesn't even look at the air pump.
My IROC does not have any emissions stuff anymore. But in Illinois they no longer check out OBDI cars, as they are exempt. Plus my IROC is now classified as a show car!
Looks like you have the firebird TPI filter system in your car. Is this correct. My 89 firebird formula 350 looks like yours, but my old iroc-z and my current 91 z-28 have the dual filter intake. Just wondering if the engine was from a donor car or if it's original.
Here's a pic of some of the parts when I did the build, and engine stats:
383 L98 TPI
Engine:
350 bored .030 over truck block 4 bolt main, line bored, magnafluxed, cylinders honed
engine internals balanced
Engine Modifications:
Stock plenum ported/simeased for the runners and throttle body
Edelbrock intake manifold and runners ported and simesed
Edelbrock Performer heads ported 64cc & 160/202 intake/exhaust
Edelbrock Valve Covers
Moroso valve cover breathers
Edelbrock BBK 58mm Throttle Body
Racetronix 37lb. Injectors
Walbro high performance fuel pump
Holley adj. fuel pressure regulator
Manly Pushrods
Crane 1.6 Roller Rockers
Comp cam Hydraulic roller:
510/540 gross lift 1.6 rockers bump up lift to 576
Duration at .050 intake:230/exhaust244
Lobe separation:112
Federal Mogol Sealed Power Speed Pro 10:5:1 forged pistons
Sealed Power Chrome Molly rings
Eagle forged piston rods
refurbished truck 400 crank turned down polished and balanced
Power Force harmonic balancer
Moroso 6qt. Pan
Edelbrock water pump
I used to have Edelbrock tes headers. Then when I decided to get rid of the smog/emission crap. I just went to the hardware store, and picked up a couple of plumber end caps. Total cost about $2.00, time to install about 10 minutes. Never had a engine light/code issue because of that mod! But of course the ever addiction to more power, forced me to sell the Edelbrocks and replace them with Hooker long tubes #2210. MY original Cat was hollowed out before I bought the car, and again never had a engine light/code issue due to that! But once again due to the pursuit of more power, when I got the Hookers I decided to replace the rest of the exhaust. So I got a Mufflix 3" system which then dumped into a 3" Flowmaster muffler.
Just to clarify:
yes, it is true that you won't get a code.
However, your engine will be running lean at times when the ECM thinks it is injecting air into the headers and rich afterwards. You will want to modify your EPROM chip to account for the change in emissions equipment. Otherwise, your engine will never achieve ideal self-learning and will run with poor emissions results, varying rich and lean conditions.
You can read more about it here: http://www.thirdgen.org/techbb2/show...hreadid=214321
Lou
Lou
http://www.thirdgen.org/techboard/te...smog-pump.html
http://en.wikipedia.org/wiki/Mass_flow_sensor
http://en.wikipedia.org/wiki/Oxygen_sensor
Even though the O2 sensor monitors the exhaust stream, injecting air into the manifolds will change the O2 reading which needs to be compensated.
If the computer is then compensating for the extra air it believes the smog pump is pushing into the headers, you will end up running lean.
Also, another misconception is that the smog pump sends air to the manifolds only at cold startup. That is also an old wives' tale. If you look at the $8D code, for example, you will see that there is RPM, O2 reading and other criteria for deciding when to divert the air into the manifolds.
Tim explains it pretty well in the TGO thread 214321 that I posted earlier and to which your thread links as well. Read through his code snippets, the conditions are visible there.
One last misconception that I hear all the time: if the car runs rich/lean, you'll get a CEL.
Not necessarily true. If it's just an intermittent condition and not too far off the scale, the ECM tries to compensate. The 80's computers didn't have enough power and programming to detect that, the new OBD-II computers usually do.
Hope this helps.
Lou
