Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
I had the KYBs many years ago. No complaints with them at the time, but since I needed to rebuild the whole front end (dont ask) I decided a change was in order. I got a full set of Bilsteins off EBay for a ridiculously low price. The KYBs made a nice improvement over the 100K+ mile original worn out pieces. The Bilsteins were MUCH better.
Unless you like adjusting things (KYB's AGX). I would go with KYB grr2 front strut & KYB gas-adjust rear shocks. This set up works for me on my 87 IROC-
Z and did not break the bank.
__________________
1987 Black Camaro IROC-Z
(original owner)
New 350 Crate Engine (TPI from 305)
SLP Intake Runners
Hotchkis STB
SLP 1 3/4 Headers
SLP 3" Catback Exhaust & Catco Cat
SLP Torque Converter(2400 stall)
1LE Aluminum Dr Shaft
Spohn Perf. Rear LCA's, Panhard Bar & SFC's (new style).
1989 B-W 9 bolt Limited Slip Rear
Four wheel Disc Brakes (11.655 dia rears)
ATI 5 Razze 17x8.5 Wheels 245/45/ZR17 Tires
DYNO RESULTS:
225 RWHP & 296 RWTQ
288HP & 380#/ft at FLYWHEEL with all Emission controls installed.
13.74 @ 98.372
A DAILY DRIVER
No, I still have them on there. The car almost looks like an inport tuner going down the road. Right after I put them on I called back to the place where I bought them from and asked them if the part number's were the correct ones and they said yes. I called another place that sell the same one's and they gave me the same part numbers.
this!!
about 6 months ago when i was going for tires and an alignment i swapped out with these myself the night before and it was a major change!! car hasnt been like this since i got it.
__________________
Richard
89 formula LB9 WS6 T-5
83 T/A 350 T-5
run it wide open till ya see god "THEN" brake !
