looking for a place to mount a msd box
i've been pushing the box around under the hood all day looking for a good spot to mount it with no luck. i removed most of my a/c stuff, i would like to remove the a/c box on the firewall but i heard i need to box off the hole or somthing. any tips on where i can put it or how to block off the a/c box so i can mount it there????
Re: looking for a place to mount a msd box
hoss its your car ,mount where ever,but why do you have to cut up heater box,it 4 small screw holes,fyi if you mount and metal especially firewall use some rubber grouments underneath to avoid annoying hum/rattle
I was lucky enough to find a non-a/c heater box and bolt it on....hello spark plugs and header bolts! i ditched my windshield washer fluid reservoir and mounted the msd box there.
On my 84 I mounted it inside under the dash. It's protected from the elements, and the heat & vibration of the motor. Definately use the shock mounts.
Originally Posted by Runin2Nite
hello mad heat and possable damage
