rear end gear help??? cant find any
i have a 1987 camaro iroc-z that has the disc rear brakes, 9 bolt borg warner (prob spelled wrong) rear end that i can not for the life of me find any gears available??? Can anyone point me in a 4:11 direction? lol or am i looking to be starting a 10 bolt drum conversion?? thanks- Chris
Re: rear end gear help??? cant find any
check 9 bolt.com, im assuming you have already calle DTS, richmond and some of the other companys? check with yukon gear, i wanna say i "think" they offer a ratio that stout.
I have the same rear. I'm planning to find a 4th gen rear with a 3.42 gear. It'll swap right in and the pics I've seen of the width difference is barely noticeable unless you know or know enough about 3rd gens to see it.
i hear ya calaban, the 9 bolts have what your looking for gear wise. im building mine for the 1/8th so i want more towards a 4:11 ish which i found on 9bolt.com. i have a set of 3:23's, and 3:70's ill see ya if you want to go that route.... where in NC are you?
I haven't been on the site for quite a while but when I was looking I found that ringpinion.com also had a lot of stuff for our BW 7.75" rear.
Here is a set of 3.73's for it. Sorry for posting in an old post ha.
http://www.ringpinion.com/b2c/Produc...ets&Source=Wiz
