pulled intake apart and now car won't start!
Old 07-09-2004, 07:21 PM
ianfromMA's Avatar
i just put my intake back together from my car sittin for a month and a half and my car won't start. won't even crank. i also have a green 3 prong plug in the back passenger side that sits above the intake and i can't find where its goin.
ianfromMA is offline
Old 07-09-2004, 09:20 PM
aklim's Avatar
What is this car we are working on? Speed Density? MAF? What engine? What are the 3 wire colors?
If it is a 90-92 350 or 305 TPI, I would suspect it is off the MAP sensor.
aklim is offline
Old 07-10-2004, 04:47 PM
Bristol's Avatar
Stupid question but hows the battery?
Bristol is offline
Old 07-10-2004, 06:16 PM
Stekman's Avatar
Sometimes the most obvious is the most overlooked.
Stekman is offline
Old 07-10-2004, 08:49 PM
Bristol's Avatar
Ask me how I know !!!
Bristol is offline
Old 07-11-2004, 12:18 AM
ianfromMA's Avatar
its speed density. that 3 prong plug...yea that was the MAP sensor i forgot to put back on (doh!). thats all set....battery was dead, jumped it....idled to 3 grand, then down to 2500 and stayed there.
i've been told to check for vacuum leaks, and to check the tps and iac. any other ideas?
Old 07-11-2004, 02:08 AM
Bristol's Avatar
Get a piece of small vacuum line and hold one end to your ear and run the other end over all the seems of the runners especially around the bolts. You will hear a loud hiss and thats your leak. Usually the bottom row where the runners meet the base plate. I coat my gaskets with " Aviation Form-A-Gasket" then I bolt the whole intake together loosely and then tigten the lower and upper working from the middle out in small torque increments ...usually 5lbs at a time. Kinda time consuming but it works.
Bristol is offline
Old 07-11-2004, 02:09 AM
Bristol's Avatar
Oh. And make 110% sure the gaskets are correct and line up perfect cause my last leak was due to inncorrect gaskets....just slightly off line. Just a heads up.
Bristol is offline
Old 07-11-2004, 07:05 AM
SharpZ28's Avatar
I have just gone through the same high idle thing after swapping out my intake manifold. The culptrit was leaking runner gaskets, after taking it all back to pieces and replacing the gaskets the problem was fixed. Now my fuel pump has crapped out and I will have the pleasure of ripping out the tank to replace that!
SharpZ28 is offline
Old 07-11-2004, 09:29 AM
aklim's Avatar
Spray brake cleaner on all mating surfaces and if it jumps up in speed, there is your leak. Check the throttle blades and make sure they are closing all the way. It could be that you need to check your TPS voltage too. Should be around 0.54V. Do you have access to a scanner?
aklim is offline
Old 07-11-2004, 11:27 AM
ianfromMA's Avatar
nope. i think i'm just gonna find someone in the around to fix it for a couple bucks cuz i don't feel like ****ing things up more...this is also my only car and i don't have the time to **** around with it
Old 07-12-2004, 10:40 PM
ianfromMA's Avatar
had a few friends over to help...****in gasket slipped when i was puttin the lower runners on
Noenav
03-01-2019 07:38 AM
thenewkid
11-27-2014 09:41 AM
Dyoung_Z28
11-25-2014 05:26 PM
USAirman93
11-24-2014 03:37 PM
07-04-2005 05:00 PM
Quick Reply: pulled intake apart and now car won't start!
