PLEASE HELP 89 tpi blowing oil out through dipstick tube.
Old 03-05-2012, 08:26 PM
crgvettez's Avatar
I have a 89 TPI and it has started blowing a serious amount of oil out where ever it can..... It has blown the oil cap off once and the dipstick multiple times....naturally I assumed too much crankcase pressure so I replaced PCV valve (which was clogged) but it didn't help and it still blowing oil through dipstick tube....... Any ideas would be GREATLY appreciated thanks
crgvettez is offline
Old 03-14-2012, 02:35 PM
Mevissen's Avatar
Re: PLEASE HELP 89 tpi blowing oil out through dipstick tube.
Have you checked the PCV valve to make sure it's working? Even though it may be new, it can still fail. Also, there's a baffle inside the valve cover. If it's plugged/pugging, the crankcase pressure will increase.
Mevissen is offline
Old 03-15-2012, 11:22 PM
Z28SORR's Avatar
Check your cyl. compression. Could be bad rings.
Z28SORR is offline
Old 03-21-2012, 10:06 AM
GRIDERMAN87's Avatar
if the pcv is operating, then its blow by thats getting bad, and prolly time to go "30"over
GRIDERMAN87 is offline
HectorM52
07-30-2017 11:46 AM
kallcium
V6 Tech
10-07-2015 03:39 PM
dylan1303
05-22-2015 12:24 PM
jmadoll
03-03-2015 10:16 AM
07-04-2005 05:00 PM
Quick Reply: PLEASE HELP 89 tpi blowing oil out through dipstick tube.
