Noisy Brake Hardware??
Old 06-09-2004, 08:28 PM
Smooothie119's Avatar
Lightbulb Noisy Brake Hardware??
I've had my '87 IROC for about 4 years now & for as long as I've had it, I've always had this clanking sound every time I hit bumps in the road. Initially I thought maybe it was a loose exhaust hanger or something. Then I thought it was my E-brake cable banging against the driveshaft, seeing as though it has never worked because the cable was all stretched out.
Then about 6 months ago I had my brakes done at Midas (previously I've always done them myself with some help from friends & family). When I found out how expensive it'd be to replace the 3 sections that make up the E-brake cable, I opted to have the old ones removed & not replace them. One of the mechanics said my brake hardware may make a little noise, & if that happens, I could take the car back & he'd adjust them for me.
The car didn't make a sound for a couple months & then started up again. So finally after all these years, I find out it's my rear brakes all along. In addition to when hitting bumps in the road, they also make the same sound, albeit not as loud when I release the brake pedal.
Is anyone familiar with this? And if so, is it an easy fix? In addition, is this a sign of something failing or going bad?
I've never heard of brakes doing this on Camaros & I've never seen posts discussing this. Any help would be greatly appreciated.
Smooothie119 is offline
Old 06-16-2004, 12:44 PM
Unhappy
C'mon, I can't be the only 3rd gen owner that's experienced this....
Old 06-16-2004, 01:37 PM
87DJP2001's Avatar
Check for a loose dust shield inboard of the rear rotors. That may be your noise.
87DJP2001 is offline
karpetcm
08-14-2015 03:02 PM
Boss002
07-24-2015 10:47 AM
Fastbird93
07-11-2015 04:37 PM
Quick Reply: Noisy Brake Hardware??
