Need a new L98 long block...
Old 08-24-2010, 06:26 PM
JohnW42598@aol.com's Avatar
My '92 L98 has developed a miss above idle. The compression on number 8 dropped to about 70lbs. I have no reason to suspect a cylinder head leak, broken piston or rings. It appears I lost a lobe on the cam... unless you have some other ideas.
What rebuilder/remanufacturer offers a VIN 8 replacement with comparable compression and roller cam specs with all the sensor provisions? I'd even consider something with more power as long as it works with my HyperChip. I don't have time (or money) to reprogram my ECM. What about warranties, core charges, shipping, etc. I figure a long block should be far less than the cost of machine work and new pistons, cam, etc. Thanks!
JohnW42598@aol.com is offline
Old 08-25-2010, 11:35 AM
Z28SORR's Avatar
If you think it's the cam. why not just change it?
If you don't have the money just get a replacement LB. Chevy and many others offer long blocks in many HP ratings, and specs. Just get one that has specs. close to yours.
http://sdparts.com/catalog/crate-engines
Just an example.
Z28SORR is offline
Old 08-25-2010, 04:57 PM
I forgot to mention it's been faithful for 185K so it's overdue for some attention... thanks for the suggestions!
Old 08-28-2010, 09:19 AM
Gtpguy's Avatar
I'd look for a L31 long block (Vortec 350 truck motor), but you would have to go and get a vortec base manifold. The heads flow much better and they stopped making this motor in 2002 or so. The 'newest' L98 will be almost 20 years old.
Gtpguy is offline
Fastbird93
07-11-2015 04:37 PM
Boss002
07-09-2015 03:33 PM
Slayer
07-04-2015 03:06 PM
Jmlcolorado
07-04-2015 08:31 AM
89 Iroc-z28
06-30-2015 11:19 AM
Quick Reply: Need a new L98 long block...
