Need help with new motor (Dist. and wiring related)
OKay i have just bought another 3rd gen camaro, and already have my motor in there. It is a '90 L03 TBI car.
I got a full motor w/carb in there, But I think to wire it up. I'm going to have to get a different distibutor. Right now I have a Early 80's H.E.I. Coil in cap model. With one 3 wire connecter with a Black, Brown, And Pink with that I think comes from the coil and goes to the cap, and another (4) wire connector with a Black w/ red stripe wire, orange w/ black stripe wire, a pink w/ white stripe wire, and a white creme color wire. This is a computer controled distubutor correct? I can't use this can I?
Also if I have to buy a non-computer controled dist., how do I wire it with the tbi harness? I read it on the tech section of thirdgen.org ,but do not really get it.
Thanks for any and all help guys.
Re: Need help with new motor (Dist. and wiring related)
The distributor you described is the one used in the '90 RS, electronic(computer controlled)advance. The trouble is that w/o a TPS(Throttle Position Sensor), the computer has NO idea of how much advance to add, especially under a load.
My advice would be to either get a H.O. Throttle Body and reinstall the TBI intake, distributor, and Throttle Body....or get a late '70's "Coil-In-Cap" with Vacuum Advance distributor, and then wire a 12 gage wire to a 12 volt(keyed, or when key is on only..) source, to the "Bat" terminal of the HEI distributor.(..like cooling Fan Relay maybe..verify with a volt meter.)
I think i've got a TPS sensor on one of my q-jets....but still dont have a carb computer.
Um, would you go with a aftermarket one, or just get one at the bone yard man?
Thanks again
Thanks again
There's nothing wrong with a salvage distributor, just remove the cap and rotor button BEFORE buying, and look for rusty springs and weights...avoid rusted HEI's...
Also if you buy "salvage", still install a "new" vacuum advance onto it.
That's what I would do, at least until I worked out all of the "bugs"..
10-31-2016 11:09 AM
01-05-2015 07:14 PM
carcrazyQT
09-17-2002 07:54 AM
