need help
Old 01-01-2010, 07:57 PM
midnightrumble's Avatar
need help
hi i have a 1987 irocz with a 96 LT1 caprice cop car motor in it. I recently got it running but it only idles for 10 seconds then dies on its own, any ideas?
midnightrumble is offline
Old 01-04-2010, 02:06 PM
Z28SORR's Avatar
Air, fuel, and spark = run. Sounds like the fuel pump is shutting off after starting.
Z28SORR is offline
Old 01-04-2010, 03:30 PM
patstoy's Avatar
Many have had to do the resistor mod to bypass the vats to allow the fuel pump to continue feeding gas to the engine.
patstoy is offline
Old 01-08-2010, 11:53 PM
Tex95Z's Avatar
You may have better luck with this thread in the LT1 section.
Tex95Z is offline
Old 01-12-2010, 06:57 AM
ayers1967's Avatar
Give us some more info . What wiring harness are you using ? How did you wire up your pump . What pump are you using. Did you have anyone reprogram your ECM to disable the V.A.T.S. system. Is all the EGR system still being used ?
ayers1967 is offline
