Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
hi i have a 1987 irocz with a 96 LT1 caprice cop car motor in it. I recently got it running but it only idles for 10 seconds then dies on its own, any ideas?
This ad is not displayed to registered members. Register your free account today and become a member on CamaroZ28.com!
Give us some more info . What wiring harness are you using ? How did you wire up your pump . What pump are you using. Did you have anyone reprogram your ECM to disable the V.A.T.S. system. Is all the EGR system still being used ?
