Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 12-08-2010, 11:13 AM   #1
Talking my 92 rs camaro
I have 92 rs camaro with a 305. Then i have a 350 from the mid 80's its rebuilt i was wondering if i can put the cylinder heads, intake, oilpan, distributor, oilpump,an everything else if its possible plz reply thank guys
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
CHRISRS92 is offline   Reply With Quote
Old 12-08-2010, 10:08 PM   #2
Re: my 92 rs camaro
depends on where in the mid 80's it was built. if its pre 87 then (if im thinking right) the dip stick is on the other side. and the heads have the same design as your 90 model. plus if its pre 87 then its a flat tappet and your motor in your 90 is a roller motor.
if you are using the stock TBI system then thats another issue, it'll run lean because the programming was for an E code 305 and your stepping up to something that needs a bit more fueling.
__________________
Richard
89 formula LB9 WS6 T-5
83 T/A 350 T-5
run it wide open till ya see god "THEN" brake !
quickchicken is offline   Reply With Quote
Old 12-11-2010, 12:27 PM   #3
GRIDERMAN87's Avatar
Re: my 92 rs camaro
you would prolly be better off just swapping the motors
__________________
96 Z28--T-tops, t56, 4.11's, cold air, true duals, JBA mid lengths, not cats, no egr, lt4 hot cam, bbk twin 52 TB, madz28 tune, it'l run
GRIDERMAN87 is offline   Reply With Quote
Old 03-28-2011, 06:20 PM   #4
Re: my 92 rs camaro
I used to have a 92 RS. I dropped 92 350 out of a box van in it. I just used the intake, throttlebody and exhaust from the 305. Had to use the injectors from the 350 tho. But the car took it really well. I would suggest just doing the engine swap.
__________________
95 z28: lt1, t56 trans, 3.42 rear end, k&n cold air intake, trickflow intake elbow, slp "air booster", accel distributer cap, rotor, and racing wires, acdelco rapid fire plugs, flowmaster catback 3" exhaust, smog pump delete, eibach pro lowering kit, and bilstein hd struts
natado125 is offline   Reply With Quote
Old 03-29-2011, 06:45 AM   #5
ws6transam's Avatar
Re: my 92 rs camaro
The whole engine will swap over, assuming that your rebuilt engine is a one piece rear main seal engine from 1986-up. If it is a two piece rear main seal engine, you will need a different flex plate than what is on your 1992's 305. I assume your 305 is worn out or broken or something?? Because otherwise, just picking the pieces off your 350 will most likely not yield you any additional power. A 350 engine has a bigger combustion chamber than a 305 cylinder head, so most likely your compression ratio will drop, negating any benefit of the extra airflow from the bigger exhaust valve.
If you want to score a home run on the first go-around, first identify your 350 engine's complete specifications.
1) Find the year of manufacture: 1987 - 1992 is best for you.
2) Is it equipped with a hydraulic roller cam? I hope so!
3) What are the cam specifications? If stock, consider getting a computer friendly performance grind.
4) Cylinder heads? Stock, ported stock, or aftermarket?
Consider if you wish to retain the throttle body EFI. There's hosts of options out there now, ranging from high-buck standalone systems to retrofit LS1 computers and Holley stealthram PFI. These systems will give you more flexibility in terms of your available modifications to your engine.
ws6transam is offline   Reply With Quote
Old 03-29-2011, 10:54 AM   #6
redneckgames's Avatar
Re: my 92 rs camaro
the op hasnt posted or been on the site for three months.
Good info for future searches though.
__________________
88 Iroc: 97 Vortec 350 w/lt4 hot cam, A4, 3.73 1/8: 8.50 & 74 mph
85 S10: 350/350 combo, Dart 200P Pro1s, 10.5:1, Lunati 40150 244/249 @ 50 .565/.543, Air-Gap, 650 DP
67 Chevelle SS: 396, 4 speed, 3.73, Flowmaster 40s
redneckgames is offline   Reply With Quote
Tags
true bowtie
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
