Motor ID #
Old 08-12-2004, 02:50 PM
red88z's Avatar
Motor ID #
I've checked out the rpo codes in my glove box and it says the engine is a 305. I ran it at the track and ran a 15.8 which is about stock for a 350. The guy I bought it from said it was a 5.7 liter 305 and it was the same 305 they put in the vette! So I think he was a little confused. Are there any other ID numbers on the engine that are easier to get to than behind the head? Thanks.
red88z is offline
Old 08-12-2004, 03:00 PM
thezisking's Avatar
Re: Motor ID #
GM never used a 305 in the Vette. The 305 is a 5.0 and the 350 is 5.7. What year is your car? I'm assuming that the PRO code is LB9. What rearend gears do you have? Look at the RPO codes for GU2, GU3 etc...
thezisking is offline
Old 08-12-2004, 03:33 PM
red88z's Avatar
Re: Motor ID #
The rear end is a 2.73 limited slip.
red88z is offline
Old 08-12-2004, 04:28 PM
87DJP2001's Avatar
Re: Motor ID #
With that 2:73 10-bolt rear and a Auto you have the LB9 305 TPI or LO3 TBI,
But Not a 350. Most sellers will say it a 350 or a Vette engine to get more money. Check the 8th digit of the VIN for the engine that came in the car. A little late doing your research after buying the car.
87DJP2001 is offline
Old 08-14-2004, 01:10 AM
ME Leigh's Avatar
Re: Motor ID #
Yes they did during the 80's in California.
To find out what engine is in there now check the casting #'s www.mortec.com
ME Leigh is offline
Old 08-14-2004, 01:25 AM
97WS6SCharged's Avatar
Re: Motor ID #
Yet another reason for California to fall into the ocean.
97WS6SCharged is offline
Old 08-14-2004, 11:47 AM
Marc 85Z28's Avatar
Re: Motor ID #
15.8 is what a stock 350 TPI should run... with a plug wire missing!
That's more inline with a stock 305 TPI with an automatic trans and a your claimed 2.73 should run. A good running stock 350 TPI should be anywhere from .7 to 1.3 seconds faster than that.
Like 87DJP2001 suggested, check the 8th digit of the VIN. 8 = original 350 TPI car, and F = 305 TPI, E = 305 TBI. I'm betting you'll find an F
Marc 85Z28 is offline
Old 08-14-2004, 12:14 PM
Dave89IROC's Avatar
Re: Motor ID #
Yea, I ran a 15.9 witha 305 TBI ( VIN E )
Dave89IROC is offline
10-31-2016 11:09 AM
alex5366
03-27-2015 03:30 PM
transam_388
03-15-2015 11:53 AM
NewsBot
12-28-2014 06:20 PM
Quick Reply: Motor ID #
