MAF Sensor Problem
MAF Sensor Problem
Ok my check engine light came on and it was throwing the 34 code which means my mass airflow sensor is bad.. ok so i go buy a new one and pop it in and then still the light comes back on after about 5mins of driving... also i think because of this my rpms drop to about 500 almost everytime i slow down to a stop and kinda bogs a lil when taking off when the car hasnt warmed up yet. anyone have any ideas?? should i try getting another one??? its under warranty
This question should be under FAQ's if you read any of the posts other than the ones on the first page you would see this question about 8 times maybe more. If you look back by the brake booster on the firewall you will see two relays that look like all of the other ones undre the hood. Go down to the auto store and buy two of them (should be around $20) and replace them ,reset your light,should be all better.
Originally posted by Jaswir
im really unfimilar with this can u give me some more details on where the brake booster is? driver side? passanger side? is the relays coming out of the firewall?
Some good pictures showing location and what they look like.
A little effort but pictures are worth a thousand words.
sence i couldnt find a picture on the website i went down to the auto parts store to just buy the relays and then put them on and they said that i dont have a burn off relay or MAF relay?? i checked by the brake booster i figured out what that was anyone have a idea or a picture they could give me??
ok i found some good pictures and heres the URL for other people having this problem
Burnoff relay
Burnoff relay
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
