Welcome to Camaro Z28!
Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
  • Participate in over 40 different forums and search/browse from over 5 million posts.
  • Upload your Camaro details to your Garage
  • Post photos, respond to polls and access other special features
  • Gain access to our free marketplace to buy, sell and trade Camaros, parts and more.
All this and much more is available to you absolutely free when you register for an account, so join our community today today!
If you have any problems with the registration process or your account login, please contact support.
Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > 3rd Gen / L98 Engine Tech
Sign in using an external account
Register Forgot Password?
Register Garage Photos Blogs FAQ Members List Social Groups Links Calendar Search Today's Posts Mark Forums Read Z28LiveVendor Directory TSBs
Reply Post New Thread
LinkBack Thread Tools Search this Thread Display Modes
Old 04-23-2006, 08:39 AM   #1
Rage's Avatar
LT1 Swap: How do you hook up MAF?
I went to connect the MAF from my LT1 to the connector on the stock 87 lid and I ran into a problem. the LT1 MAF is a 3 pin connector, my stock MAF is a 5 pin. Is there anyway to splice my old sensor into the new? What did you do?
This ad is not displayed to registered members.
Register your free account today and become a member on CamaroZ28.com!
__________________
1987 IROC-Z Camaro,305 TPI
LT1/T-56 on the way
http://hometown.aol.com/rage502/myhomepage/profile.html
Rage is offline   Reply With Quote
Old 04-23-2006, 04:44 PM   #2
Re: LT1 Swap: How do you hook up MAF?
so are you tring to run your 87 ecm with LT1 MAF?
cause that won't work,
the MAF's don't work the same
89Vert is offline   Reply With Quote
Old 04-23-2006, 05:04 PM   #3
Since I'm not a third gen guy, I'm probably wrong, but weren't all third gen engines speed density?
__________________
1994 Z28 M6 - Bright Teal, K&N, Loudmouth, WS6Store short stick, !CAGS, 1LE elbow
Old Car: 1995 Camaro, Mystic Teal, 3.4, A4
jah1542 is offline   Reply With Quote
Old 04-24-2006, 11:44 AM   #4
Rage's Avatar
No and No. Im running the LT1 ECM and wiring harness but the MAF plug itself on the LT1 harness is a 3 pin, the receiving part of the MAF on my stock lid is a 5 pin.
I believe MAF was used on all TPI units until 1990, then they switched to SD.
__________________
LT1/T-56 on the way
Old 04-24-2006, 11:54 AM   #5
LWillmann's Avatar
You're probably going to need an LT1 MAF then.
__________________
2005 Dodge Grand Caravan.
Yeah, it's an f'in Minivan!
LWillmann is offline   Reply With Quote
Old 04-24-2006, 12:58 PM   #6
so you are tring to run stock maf with LT1 ECM and harness?
have to get the LT1 MAF
Old 04-24-2006, 01:02 PM   #7
Quote:
for some reason they went SD in 90,
IMO MAF is a better,
but on a 3rd gen MAF was a limited 16kb file
when they went to SD it got a larger 32kb file, which allows for better tuning
Old 04-24-2006, 01:29 PM   #8
fast 93 z's Avatar
2 pins out of the 5 pin connector may be for a IAT sensor.
__________________
Tony Shepherd
93 Z28 red www.fast93z.com
396 stroker LT1 Single plane AFR 235 heads
8.68 @ 153.51 mph (157.03 best) (current LT1 Nitrous record holder Nov 2010)
fast 93 z is offline   Reply With Quote
Old 04-24-2006, 01:52 PM   #9
Quote:
maf burn off I belive, they have an IAT sensor on the plenum
Old 04-24-2006, 03:29 PM   #10
fast 93 z's Avatar
Quote:
Oh ok...I have seen some Mafs have the IAT built into the sensor.
__________________
Tony Shepherd
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
