LT1 cam in 1991 305 TPI ?
Re: LT1 cam in 1991 305 TPI ?
In the B-body world, we refer to that cam as 'The Truck Cam'.
Why? Because it generates torque! Now, the TPI intake & long runners will do that as well.....but you are talking about the 305ci engine. That lil' puppy can always use a bit more help in the torque department.
You'll probably need to burn a new chip for the cam swap. I recommend PCMforless .....they have massive experience with the B-Body LT1 cam and with the TPI cars!
Good luck!
KW
EDIT: Forgot to mention.....you'll need to take out the dowel pin from the front of the cam......should be able to pull it out with a pair of pliers......
That little bitty 305tpi makes as much torque at the wheels as an lt1. An LT1 cam isnt going to do much over the L98 cam. The LT1 cam specs are not much improved over the L98 cam. All speed density tpi cars had the same L98 cam. My auto single cat 91 Trans am dynoed 187 HP/ 273tq. Not far from my brothers stock auto 97 t/a 230HP / 272tq. Just food for thought.
Just food for thought.......
KW
I am running this exact setup in my '86 Trans Am ('91 305 long block with LT1 cam). There is a noticable difference over the stock cam. I also have headers and a slightly modified '89 TPI tune. If the motor is apart and you've got the cam, go for it! BTW, my car club is having a dyno meet next month. I will post up numbers afterwards.
