LT1 In 3rd Gen swap. Wiring write up.
#17
See you have not post in a while.
I just swap a 95 engine, Harness, Computer and transmission into a 96 body, The harness plugs up the same but some of the wires are different on some of the connections, Example:My 95 4pin black(C210) does not have the orange constant power wire on the computer side.
My question is can I use the 96 harness even though it has the crank trigger on the front or do I need to bypass it some how, Thanks.
#19
Re: LT1 In 3rd Gen swap. Wiring write up.
I'm really confused with the bulk connector c100 from the rs, it says purple to starter solenoid and then the 4 pin connector from the lt1 is the same, those that mean splice then together? or do they go separate to the starter solenoid
Please help, their good instructions but I'm a bit confused
07-04-2005 05:00 PM
JasonD
07-15-2002 02:17 PM
