L98 T56 computer
L98 T56 computer
seeing as how the L98 didnt come with a t-5 transmission (all automatic) if i wanted to put an L98 in my camaro with a t-56 transmission, how would i get a computer that would work with that? does it need to be custom burned or is there a performance PROM chip that allows the use of a manual transmission?
thanks for the help guys. but thre's no lines going into the tranny at all? nothing like an automatic's TV cable? nothing what so ever?
whos the best company to buy an aftermarket ECM from?
You don't need an ECM. You need an EPROM. I would call the people at www.fasterproms.com and have them burn you a chip for $350. It will be more aggressive and later when you want to do mods, it will cost you about $150. By the way, the first burn for $350 is complete when they have dialed it in. You can borrow their Diacom to take readings because each car is slightly different. That way it gets it dialed right in instead of the Hyperjunk which is some "off the shelf" unit. Get it from whomever but don't buy an off the shelf unit. Get somethign where they take readings and make adjustments till it is done.
how would I use fasterproms equipment if they are an online company?
i was looking at hypertech units and they only gave an option for the automatic 350 TPI, which is what i was afraid of.
do the VSS wires have to go to the computer or just to the speedometer?
so do i just tell them what i have on the engine, the heads, the intake, the injectors, the ignition system, the exhaust headers and things like that?
VSS sends a signal to the computer and the computer drives the speedo (assuming your car has an electronic speedo stock.) If your stock speedo is cable-drive, you'll need to either modify the tailhousing or buy a cable-drive box (i.e. the Cable-X from Abbott.) See this thread on TGO for more info. It may also help to run a search in that forum.
