HSR Fuel Pressure and Timing Question...
Old 08-08-2004, 01:54 PM
dj haf's Avatar
Cool HSR Fuel Pressure and Timing Question...
im putting the hsr on right now, and i wanted to know if anyone had suggestions on where i should set the timing and fuel pressure? i have a 350 bored over .030, comp cams 503 cam with 1.6 rr's, ported l98 heads, around 10:5 to 1 cr, and 24# svo's. with the tpi setup, i had the fp set at 44-45 psi on my tpi setup because it seemed to run pretty good with 45 psi. i heard that the hsr likes a lot of timing and a lot of fp, so i just wanted to find out if anyone had some advice to give me for my application. thanks guys
dj haf is offline
Old 08-08-2004, 04:32 PM
mrr23's Avatar
Re: HSR Fuel Pressure and Timing Question...
just start at the same point. but just to give you an idea on my 360 i had with the ZZ4 cam and L98 heads, i used 45 psi and timing was 36* by 2500 rpm. now on the 383, i used 55 psi and 36* by 2500 rpm. on both, i had the 24# accel injectors.
mrr23 is offline
Old 08-08-2004, 10:52 PM
aklim's Avatar
I used stock fuel pressure and 6 deg timing.
aklim is offline
Old 08-09-2004, 12:14 AM
dj haf's Avatar
6* btdc? have you had your car tuned?
dj haf is offline
Old 08-09-2004, 12:50 AM
aklim's Avatar
Yes I did. Timing was set at 6 deg and the pressure was about 45-57. It made about 410 HP at the wheels. I don't know what the ECM was supposed to advance it to but that was what I set it at. It was dyno tuned at HiTechMotorsport in Ramsey, MN.
aklim is offline
DirtyDaveW
12-01-2016 05:37 PM
Gtpguy
01-26-2015 04:50 PM
Alex Barnes
01-24-2015 10:21 PM
07-04-2005 05:00 PM
F(ast)-body
02-26-2003 09:05 AM
Quick Reply: HSR Fuel Pressure and Timing Question...
