How much HP does a '88 350 TPI IROC have?
Old 10-29-2002, 05:01 PM
LS1Nat's Avatar
As you can see from my other thread, I'm picking up this car tomorrow. What was the stock HP rating of these cars? What rear end options were available? Where is the option code list located in the car? What performance numbers do these cars run? I remember my brother running this car a few years ago aand it ran a 14.7X at 94 MPH. Is this good for this car or can it run better? Thanks for looking!
LS1Nat is offline
Old 10-29-2002, 05:07 PM
BamaZ28's Avatar
Once you get the car, grab the RPO sheet and ru them to find out all you rear end specs and interesting options on the car. Also I think it was 210 HP and just shy of 300ft lbs.
BamaZ28
BamaZ28 is offline
Old 10-29-2002, 07:50 PM
LS1Nat's Avatar
Only 210? I thought it was more then that. I think the L98 equipped Vettes from '88 had 245 hp. I would've thought they would've been closer in hp rating. Jeez, looks like I have a good amount of work to do to make this car fast.
LS1Nat is offline
Old 10-29-2002, 08:03 PM
BamaZ28's Avatar
Don't take MY word for it. 210 just stood out for that combo, for some reason. Look around on this site, and hopefully should find some better news, I will look around too
BamaZ28 is offline
Old 10-29-2002, 08:06 PM
BamaZ28's Avatar
http://www.thirdgen.org/newdesign/tech/techdb.shtml
they say 230hp/330ft lbs
boy was I off!!! check it out!!
good luck
BamaZ28 is offline
Old 10-29-2002, 08:08 PM
LS1Nat's Avatar
That's a little better! Thanks for your help!
LS1Nat is offline
Old 10-30-2002, 04:21 PM
fbird95's Avatar
The L98 was obtained in 88' by ordering B2L. GM listed the car at 230 hp.
The Vette got better flowing heads and exhaust.
The corvette of 1988 L98 was rated at 240 hp for convertable, and 245 hp for other models.
the 5 hp difference was due to the less restrictive exhaust being classified as too loud for convertables.
fbird95 is offline
Old 10-31-2002, 07:42 PM
n2ceptor's Avatar
HERE is what NHRA has on stock class...
93Z Will
n2ceptor is offline
Old 11-01-2002, 01:19 AM
3rd Gen Tech Moderator
Kevin91Z's Avatar
The RPO list should be in the glove box between the seats.
Rear ends will be the 9-bolt, and either the 2.77 ratio or the 3.27 ratio depending on if you have the G92 performance option. Gears and posi's are expensive, about $300 for the gears and $400 for the posi's. 230 HP/330 TQ are the correct numbers for an 88 TPI 350.
Congrats on your purchase!
Kevin91Z is offline
G-BODYT56
01-14-2022 11:14 PM
HAWG
09-25-2015 11:41 AM
Matt Dreessen
09-09-2015 09:58 PM
gonzo275rltw
09-05-2015 06:26 PM
Quick Reply: How much HP does a '88 350 TPI IROC have?
