How much HP does a '88 350 TPI IROC have? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 10-29-2002, 05:01 PM   #1
As you can see from my other thread, I'm picking up this car tomorrow. What was the stock HP rating of these cars? What rear end options were available? Where is the option code list located in the car? What performance numbers do these cars run? I remember my brother running this car a few years ago aand it ran a 14.7X at 94 MPH. Is this good for this car or can it run better? Thanks for looking!
LS1Nat is offline   Reply With Quote
Old 10-29-2002, 05:07 PM   #2
Once you get the car, grab the RPO sheet and ru them to find out all you rear end specs and interesting options on the car. Also I think it was 210 HP and just shy of 300ft lbs.
BamaZ28
BamaZ28 is offline   Reply With Quote
Old 10-29-2002, 07:50 PM   #3
Only 210? I thought it was more then that. I think the L98 equipped Vettes from '88 had 245 hp. I would've thought they would've been closer in hp rating. Jeez, looks like I have a good amount of work to do to make this car fast.
Old 10-29-2002, 08:03 PM   #4
Don't take MY word for it. 210 just stood out for that combo, for some reason. Look around on this site, and hopefully should find some better news, I will look around too
Old 10-29-2002, 08:06 PM   #5
http://www.thirdgen.org/newdesign/tech/techdb.shtml
they say 230hp/330ft lbs
boy was I off!!! check it out!!
good luck
Old 10-29-2002, 08:08 PM   #6
That's a little better! Thanks for your help!
Old 10-30-2002, 04:21 PM   #7
The L98 was obtained in 88' by ordering B2L. GM listed the car at 230 hp.
The Vette got better flowing heads and exhaust.
The corvette of 1988 L98 was rated at 240 hp for convertable, and 245 hp for other models.
the 5 hp difference was due to the less restrictive exhaust being classified as too loud for convertables.
fbird95 is offline   Reply With Quote
Old 10-31-2002, 07:42 PM   #8
n2ceptor's Avatar
HERE is what NHRA has on stock class...
93Z Will
n2ceptor is offline   Reply With Quote
Old 11-01-2002, 01:19 AM   #9
3rd Gen Tech Moderator
The RPO list should be in the glove box between the seats.
Rear ends will be the 9-bolt, and either the 2.77 ratio or the 3.27 ratio depending on if you have the G92 performance option. Gears and posi's are expensive, about $300 for the gears and $400 for the posi's. 230 HP/330 TQ are the correct numbers for an 88 TPI 350.
Congrats on your purchase!
Kevin91Z is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Chevrolet Camaro Z28 vs Lada 2107 HAWG Drag Racing Technique 2 09-25-2015 11:41 AM
New and Used C4 LT1/TPI/SBC parts for sale G-BODYT56 Parts For Sale 2 09-25-2015 05:10 AM
Sputtering under hard acceleration Matt Dreessen Fuel and Ignition 1 09-09-2015 09:58 PM
L98, LTx, or LSx, simplest to install on '87 IROC? gonzo275rltw LT1 Based Engine Tech 4 09-05-2015 06:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
