Does it matter which way the temp sensor is wired?
Old 02-13-2004, 10:57 PM
kbog54's Avatar
Ok, quick question, for my temp sensor, there is a black wire and a yellow wire that connect to the sensor. Somebody removed the original weatherpack connector, and put in a generic one with two white wires. Does it matter in which order the wires are hooked up? Or are the wires reversible like a heated O2 sensor?
thanks
kbog54 is offline
Old 02-14-2004, 06:59 AM
greezemonkey's Avatar
shouldn`t matter, the sender is just a "ressistor" and it will have the same either way
greezemonkey is offline
Old 02-14-2004, 10:12 AM
aklim's Avatar
This is the one in the front of the car, right? That is the one that the ECM reads. The other temp sensor is on the head at the driver's side and that is 1 wire.
BTW, if it is reversed, your car will go backwards.
J/K Geezer is right, shouldn't matter.
aklim is offline
Old 02-16-2004, 11:20 AM
kbog54's Avatar
ok, thanks guys
kbog54 is offline
HectorM52
07-30-2017 11:46 AM
AlaskaZ28
01-01-2015 12:30 PM
AlaskaZ28
12-16-2014 07:24 PM
AlaskaZ28
12-10-2014 02:39 PM
AlaskaZ28
12-10-2014 02:37 PM
Quick Reply: Does it matter which way the temp sensor is wired?
