how do things just go out of adjustment, like timing or carburator
does it happen, like for example im having a starting problem currently and my engine cranks really funny and slowely, could this be a timing issue?, i diddnt touch anything timing related
It is possible for the dist. to wander if you did not tighten the clamp down tight enough.
IF its tight and timing is right... just do a tune up. Fuel filter, plugs, wires, cap and rotor, maybe even a decarb.
Originally posted by irocz383
It is possible for the dist. to wonder if you did not tighten the clamp down tight enough.
Well they might "wander" but I dought the "wonder"!!
I know! I'll go crawl back in my hole now.
I've corrected it now
i just bought a brand new battery, still does it, could starter be going? im going to try and disconect the primarys from the distributor tomarow so that i know that i wont get any spark at all
and then try to crank and see if it still goes slow
i think the connection on the battery might be bad, not corroded just not tight, i think that the little bolt is stripped becasue it wont tighten, i hope thats it becasue its 5 verses about 60 $$
any other possibilities that i can check out?
10-31-2016 11:09 AM
Hal Fisher
09-14-2002 09:36 PM
BLUESMAN
08-26-2002 06:07 AM
