Help Picking out Gears...
Old 08-12-2004, 11:41 AM
dj haf's Avatar
Cool Help Picking out Gears...
i want to switch from 3.23's to 3.73's soon becaues i just installed the HSR, a nice cam, and a 3000 stall torque converter. i want to ask you guys for your suggestions on what i should do to my rear end. i want to, like i said, install 3.73's, but i also want to clean up the rear a little and make it a bit more stronger. thunder racing sells a gear kit for about $400, but i wanted to know if anyone has any better suggestions to help me beef up my rear along side with the 3.73's. thanks guys for all the help
dj haf is offline
Old 08-13-2004, 01:25 PM
Ucantcme57's Avatar
Re: Help Picking out Gears...
http://www.lpwracing.com/home.htm
Get the ultimate cap, with axle tube brace, solid pinion spacer, some 3.42 detroit locker, install axle tube brace, weld around the tube ends instead of spot welding... Should hold around 500hp with an automatic and a 3000 stall
Ucantcme57 is offline
Old 08-14-2004, 08:08 PM
AutoRoc's Avatar
I did Richmond 3.73's, a T/A Support cover, Raytech crush collar, Auburn Pro Posi, and Royal Purple fluid. Stock axles still and I'm thinking I'd rather break an axle than a ring gear so they're staying for now(knock on wood!). I kept my old 3.08 rear end also as a backup. Sinking money into EVERY modifcation possible still wouldn't give me a solid piece of mind with this rear. Something I do think about is a Cryogenic process for the Ring and Pinion set. Never seen it done but I like the idea. That at the support cover I like.
So far it's seen a 1.80 60 foot and still no whine. Install and setup are as or possibly even more important than the parts inside I'd say.
AutoRoc is offline
Old 08-15-2004, 04:14 AM
BadAzzRS's Avatar
I would say go with stock GM gears...they seem to set up better then most aftermarket gears...they run quieter too, also order the solid pinion spacer from drivetrain direct to use in place of the stock crush sleeve. Then have the axle tube seams welded completely where they are spot welded. Get some superior axles, they are great axles and reasonably priced. As for the posi unit get an Eaton...better then the auburn and far better then the zexel torsen units they use the 4th gens. Top the whole thing off with an aluminum support cover from summit...its a great piece and for the money the damn thing even comes with ARP stainless cover bolts. I wouldnt recommend the axle brace for the simple reason that if your gonna make enough HP to warrant an axle brace on the stock rearend then its time to upgrade to a 12 bolt or 9 inch, IMO.
BadAzzRS is offline
Old 08-15-2004, 10:49 AM
aklim's Avatar
GM gears do cost about twice to 3 times more than Richmond Gears tho
aklim is offline
Old 08-15-2004, 05:34 PM
Ucantcme57's Avatar
Solid Pinion Spacer + Cover + Brace Kit + ring and gear set = $600
Moser or Currie Rear End = $3000
Um... I'm gonna break one before I buy the other...
Haven't broke it yet.. Should be fine with an automatic..
Formula Steve
09-19-2023 08:31 AM
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
WobblySausage
10-07-2015 02:44 PM
WobblySausage
10-07-2015 10:09 AM
1994formy
Wheels and Tires
09-28-2015 01:11 PM
Quick Reply: Help Picking out Gears...
