Help me figure out my CR
i did a leakdown test on my car and this is what i got...
cyl 1: 180 psi
cyl 2: 180 psi
cyl 3: 180 psi
cyl 4: 180 psi
cyl 5: 178 psi
cyl 6: 175 psi
cyl 7: 180 psi
cyl 8: 180 psi
from the results i got, what would you say my compression ratio is? i know there's an equation on how to figure out the CR by just checking the compression on each cylinder, but i can't find it anywhere =\ thanks for the help
cyl 1: 180 psi
cyl 2: 180 psi
cyl 3: 180 psi
cyl 4: 180 psi
cyl 5: 178 psi
cyl 6: 175 psi
cyl 7: 180 psi
cyl 8: 180 psi
awesome. i was aiming for 10:5 to 1 so im pretty happy.
have 2 more questions... first, would it be wise to set the plug gaps to .050 with an msd 6al box connecting to a hypertech ign. coil (53k volts) with that kind of compression? and second, would it be a good idea to raise the car's fuel pressure if i have higher compression? thanks in advance
Maybe 1 or 2 psi but more than that, I would say you need to get the chip recalibrated.
well, i have the HSR, comp cams 503 cam, and a 3000 rpm stall converter from edge racing converts waiting in my room to go into the iroc. when everything's installed, im going to get her dyno tuned so that she's runing the best she can thanks for all your help aklim
WobblySausage
10-07-2015 10:09 AM
Ryan Ramsaran
09-19-2015 08:43 PM
NewsBot
09-14-2015 02:02 AM
