Help! Fuel pump won't shut off - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 02-02-2004, 04:08 PM   #1
Yep, just like it says. Whenever I turn the car off I can still hear the fuel pump running. I've just disconnected the battery for now. I unplugged the relay and that did absolutely nothing. Nobody I've talked to has ever heard of this happening. Anybody have any ideas?
1SLOWIROC is offline   Reply With Quote
Old 02-02-2004, 04:36 PM   #2
anyone?
Old 02-02-2004, 04:51 PM   #3
try taking off the fuel pump fues by the battery... that'll turn it off for sure.
dj haf is offline   Reply With Quote
Old 02-02-2004, 07:06 PM   #4
is this Tim? Will the car still start and run?
amc91z is offline   Reply With Quote
Old 02-02-2004, 07:09 PM   #5
My guess is that your fuel pump relay is messed up and not shutting off. So get a new relay, its located in back of the brake booster. That shud solve the problem, if not come back and let us know. good luck.
transxtreme is offline   Reply With Quote
Old 02-02-2004, 07:22 PM   #6
happened to my towncar, wire a temporary switch under the hood to break the wire until you can get the regulator replaced.
while your at the scrap yard grab all the regulators for later.
sucks when your battery dies every day and you dont kno why eh?
kevin 2.8 is offline   Reply With Quote
Old 02-02-2004, 07:37 PM   #7
Yes, this is Tim. Yes the car will start and run. When I was driving home today, I could tell it was getting too much gas because it started to bog really bad. I'll try the fuse here in a little bit. We weren't sure which relay was the right one, so we disconnected all of them and it still continued to run.
Old 02-02-2004, 08:12 PM   #8
Fail safe
Your car has a fail safe for the pump, the oil pressure switch will always keep the pump running if the primary circut fails (i.e the relay or the fuse) the fuel pump will continue to run if this switch sticks closed. The switch will only send power to the pump when it has pressure under it or it goes out.....Start the car unplug the relay and the fuse..it should stay running...now disconnect the oil pressure switch (it should die) Try this and see if it works, reply back if it does not.
greezemonkey is offline   Reply With Quote
Old 02-02-2004, 08:19 PM   #9
Where is the switch? I'll probably just mess with it tomorrow since its already dark and not exactly warm right now. Thanks for the help.
Old 02-03-2004, 05:02 AM   #10
some v8`s have one next to the dist, some have them just above the oil filter,...the buick v6 is right front of the block, the chev v6 is next the filter
Old 02-08-2004, 06:14 PM   #11
1fastformula's Avatar
Thumbs up
Greeze is right on the money....Mine did the same thing. Went out and unplugged the Oil sensor and it shut off. Replaced relay and plugged oil sensor back and all is well. You oil sensor is right above the oils filter. It is about an inch long and has one wire coming out of the very end of it.
Later
1fastformula is offline   Reply With Quote
Old 02-08-2004, 06:17 PM   #12
any luck Tim?
Old 02-09-2004, 07:50 PM   #13
No. I replaced the relay today and still have problems. I think the switch that everyone's talking about may not be in the same place anymore due to the engine swap. I looked for it but I never found it.
Old 02-10-2004, 07:22 PM   #14
The oil sending relay should be where we stated.......I had to change mine out to get the fuel pump back on track. Look CAREFULLY!!! It is right under the driver side header (if manifold...it might be harder to see) near the rear plug. You do have a oil pressure gauge right??? what year is the engine??
Later
Old 02-10-2004, 08:24 PM   #15
Fast formula is right! there is that spot by the oil filter (just above it ) or next to the dist. base behind the intake manifold. THESE are the only two places to get oil pressure readings from a small block of your year....the early small blocks had a galley in the front just below the front of the intake manifold, but unless it`s an older motor, that`s outta the question.....I have an 85 that came with the H.O. tpi and it had the switch branched off the same port as the sender. Next to the dist. on the right side...Take a good look and unplug it....Mine was a two pronge switch , but later models had a three pronge switch. If this doesn`t help seek professional help.
Reply
Thread Thread Starter Forum Replies Last Post
Project Frankenbird - spring 2015 - D1SC 383 Lt4, advice welcome! LONG dbusch22 Forced Induction 6 10-31-2016 12:09 PM
97 Camaro fuel pump relay chattering Scottyboy Fuel and Ignition 1 02-11-2015 11:28 PM
93 trans am no spark all of a sudden FIREBIRDMARK1 LT1 Based Engine Tech 2 01-07-2015 04:36 PM
93 z28 won't start please help Jessie4tin General 1967-2002 F-Body Tech 13 01-07-2015 09:53 AM
2002 B4C fuel pump replacement issues? ANDYZ28 Fuel and Ignition 3 12-29-2014 10:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
