Re: has oil pressure but no oil on top end.
You have to run it longer than that to get oil up there.
__________________
95 Z28 M6 - AFR 180 heads, Comp cam 221/227.542.560,112 lsa. 1.6 pro magnum rr, 30 lb/hr svo injectors, comp-r lifters, melling hv pump, clevite brgs, LT4 extreme roller timing,poly eng/trans mounts, slp mid headers, 3"ory, magnaflow high flow cat/catback, QTP cutout, msd ovc wires, pcm for less emissions tune, moroso cai, slp 3-point sfc's, bmr stb,tq arm,lca's,relo brackets, earls brake lines, 4.10 gears, deleted air, egr, skip shift.
