Gauges..
Old 07-04-2004, 07:46 PM
MetalheadZ28's Avatar
Unhappy Gauges..
Can anyone tell me if my 87 Camaro has a wire that makes my gauges work?? And if so where is it suposed to be? Because only my RPM is working and i sucks!
MetalheadZ28 is offline
Old 07-04-2004, 11:00 PM
2nd question:
How do u change breaklights or a 3rd Gen. Camaro??
Old 07-05-2004, 08:34 AM
firebirdjosh's Avatar
Re: Gauges..
Care to rephrase that so it makes sense?
firebirdjosh is offline
Old 07-05-2004, 10:00 AM
Ok. Is there a wire that make the (Gas, Battery, Speedometer, Millage, Temp.) gauges work? Since they all broked down at the same time, or were there sensors in 87 Camaro's?
Old 07-05-2004, 10:08 AM
Stekman's Avatar
If they all went at the same time, i would suspect the harness plug in at the rear of the cluster. There are 2 plug in connectors, check for loose fittings on both, as i forget which harness feeds which gauge.
Stekman is offline
Old 07-06-2004, 02:32 AM
DPG Omaha's Avatar
There is also a fuse for the gauge cluster, but since your tach works, I'm not sure if that's the case. Easy thing to check anyways.
DPG Omaha is offline
Meen95z
07-21-2009 06:06 PM
lt1junkie
03-20-2008 08:13 AM
dist0rtion_69
08-08-2007 03:08 AM
woodywagon
02-03-2007 07:23 AM
dist0rtion_69
01-24-2007 11:25 AM
Quick Reply: Gauges..
