Gaskets for a 3970010 block? - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 08-28-2006, 11:57 AM   #1
I have an early 3970010 block drivers side dip stick that Im using for my 383...I need to get an oil pan gasket for it...someone told me that they do not make 1 piece gasket for the older blocks...true?..if they do make one does anyone know the part number or can point me to one?
also Ive been reading and what is this about on the 1 piece having either the thick style front seal of the thin style front seal? how do I know which one Ive got?
thanks
Wishmaster is offline   Reply With Quote
Old 08-28-2006, 03:22 PM   #2
Stephen 87 IROC's Avatar
Re: Gaskets for a 3970010 block?
The front seal for the oil pan depends on the pan and timing cover, not the block. Typically, oil pans from 75 and up use the thick front seal. 1974 and eariler use the thin front seal.
Aftermarket timing covers are designed for the thick front seal.
Felpro one piece gasket for LH dipstick and thick front seal is #1880
Felpro one piece gasket for LH dipstick and thin front seal is #1885
Both are in the $30-$40 range from Jegs or Summit.
Stephen 87 IROC is offline   Reply With Quote
Old 08-28-2006, 03:39 PM   #3
Im using an aftermarket oil pan, what kind I have no idea but its aftermarket...and of course Im getting an aftermarket timing cover...so should I get the thick front seal gasket?
I want a 2 piece timing cover but if I get a one like say from AZ or Advance..would that be considered aftermarket?
Old 08-28-2006, 11:23 PM   #4
ws6transam's Avatar
I'm using an early 1969 block, casting number ...something...something...388. It's from a Nova SS, 350 4-speed car I think. Anyway, I've got a one-piece gasket in there, but I forgot where I bought it from. They are made, and you need to simply trim off the appropriate tabs to use it as either a passenger or driver dipstick oilpan design.
ws6transam is offline   Reply With Quote
Old 08-30-2006, 10:03 AM   #5
I just had a brain farT!....if my dipstick is on the drivers side...what would that be called? LH or RH?..I guess it depends on how you look at it..
Old 08-30-2006, 11:36 AM   #6
Quote:
NO, it's always left to right as you sit in the car. Drivers side is left, pass. side is right.
It's the same with ALL vehicles; boats, trains, planes, and auto's. Except with boats it's port and starboard.
Z28SORR is offline   Reply With Quote
Old 09-04-2006, 03:05 PM   #7
http://store.summitracing.com/partde...&N=700+150+150
will this work? I assume its for either and like you said, you just trim the other tab off..
Old 09-04-2006, 10:11 PM   #8
ws6transam's Avatar
Yes, that looks like the kit. '55 to '85 will cover that 0010 block just fine.
Old 09-18-2006, 08:29 PM   #9
all after market oil pans use the thicker front seal for the oil pan gasket.
mrr23 is offline   Reply With Quote
Old 09-19-2006, 09:55 PM   #10
The all years set should have both thin and thick rubber seals.
tom2 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Rebuilding the Lt-1 from 0 ... Where do i begin ? Sergio LT1 Based Engine Tech 11 01-27-2016 05:27 PM
Oil in Coolant Plus lean and misfire code kallcium V6 Tech 3 10-07-2015 04:39 PM
Headers from hell... 95z_28_camaro_4_Ivan General 1967-2002 F-Body Tech 27 05-08-2015 10:56 AM
LT1 "D" port exhaust gaskets 4586 General 1967-2002 F-Body Tech 2 04-29-2015 02:43 PM
Engine overhaul- main and rod bearings carl.froehlich LT1 Based Engine Tech 6 03-13-2015 01:38 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
