oil pan gasket sealing?
hey, you guys using a 1 peice gasket...when you put it on did you use anything with it or just put it on dry? the motor is on an engine stand and I just put a little RTV on the ends of the timing cover.....I just want to make sure this thing doesnt leak once I get it in the car....so should I take it off and put any RTV anywhere else on the gasket?
