Gas in Charcoal Canister
The black canister behind the driver side head light is filled with gas. I took it apart and its leaking gas from the hose to the gas tank. This problem just came out of nowhere and its filled the entire canister and is leaking out the vent port in the top of the canister. Anyone have any idea why this would be happening ?
Thanks for the help.
CMC
CMC
Originally posted by greezemonkey
canister purge valve is stuck open( constant vacuam on the canister instead of a pulse ..more than likley that charcoal got up the hose into your carb or fi
You will just have to get another cannister, I think.
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
