fuel system screwy LG4 (pump, filter, bad gas, sensor??) code 21
heres the story i fill the tank up completely with 93 octane and i throw in a bottle of chevron (w/ techron) fuel/carb cleaner in yesterday (when it was running great). today i go to drive my car and its running like crap... rough idle, low idle, wants to stall, terrible acceleration no power, check engine light comes on for a little while then goes off the choke light goes on and off sometimes too
i run the code and i get 21 which is:
High voltage at throttle positon sensor
so what you guys think
i have a 4bbl quadrajet in a 83 z28
ok i checked my TPS and i get 2.81 at closed throttle and 4.6 at wot so it makes sense that the comp is saying high voltage at tps
the throttle blade also seems like its not even touching the little stop screw on the drivers side of the carb, maybe becasue its on the fast idle cam?
but now i got other big problems and things got worse
i replaced the fuel filter and that diddnt help at all when i took the fuel line back off to see if it was still dry, fuel came out all over the engine so i guess im getting some fuel.
im stalling out imediatly after startup and the smoke comes out of the carb im getting nervous please help me
on a side note could the PCV system have anything to do with it?
10-31-2016 11:09 AM
07-04-2005 05:00 PM
