Fans work sometimes?
Old 07-21-2004, 11:57 AM
bmillington's Avatar
I've started having a overheating problem. I noticed the fans are only coming on with the A/C is on. I tried lowering the enable and disable fan1 and 2 temps and increased the fan1 disable speed, no help. Yesterday I noticed the fans were off and the engine was over 220, turned the engine off and back on and the fans were runing.
The fans always work in A/C mode, so no loose wire at fans
Wouldn't I get some kind of check engine light if the ECM lost its signal from the temp sensor?
Would a header touching the factory oil cooler be a bad thing?
bmillington is offline
Old 07-21-2004, 06:30 PM
lordmetalz28's Avatar
Re: Fans work sometimes?
fan relay, trust me happens to me every 6 months
lordmetalz28 is offline
ChrisFrez
02-01-2015 08:26 AM
ChrisFrez
01-25-2015 08:06 AM
ChrisFrez
01-18-2015 08:05 AM
ChrisFrez
01-11-2015 03:47 PM
07-04-2005 05:00 PM
Quick Reply: Fans work sometimes?
