Fan Switch Location
Old 08-05-2010, 06:07 PM
native1031's Avatar
Fan Switch Location
So I received my fan switch and thermostat. Problem is I cant find where the fan switch goes. I was told its on the passenger side by the back spark plugs. Maybe if someone had a picture or a way to help me. Its all original so im getting mixed up a bit with all the hoses and wiring. Im also gonna be changing the coolant from anti freeze to distilled water. Every mechanic told me it helps keep it cooler in the summer but in the winter to switch it to antifreeze again.
native1031 is offline
Old 08-15-2010, 10:06 PM
Gord's Green Z28's Avatar
You won't be able to see if from the top. You need to look from below. It's between the 6 and 8 spark plug area on the passenger side.
Gord's Green Z28 is offline
meissen
06-01-2015 07:59 AM
cristian1311
11-23-2014 02:22 PM
Rich_z28
09-13-2002 03:35 PM
troywg
09-12-2002 07:28 PM
Rich_z28
09-08-2002 12:00 AM
Quick Reply: Fan Switch Location
