HELP!! 87 Iroc build
Old 11-03-2009, 10:25 PM
Trampus83's Avatar
Exclamation HELP!! 87 Iroc build
I have an 87 Iroc, The 350 has been bored 40 over. I need some info on what head cam combo to run, Im using the stock tune port...
Trampus83 is offline
Old 11-04-2009, 04:24 PM
rik89gta's Avatar
Well, what are your goals for the car power wise? Is it your daily driver? Or do you plan on making it an all out drag strip car? We need more info before helping you decide on modifications.
rik89gta is offline
Old 11-04-2009, 09:36 PM
Trampus83's Avatar
wel it is going to be a Strip and street... I wont be driving this every day it will be a weekend ground and pound... I bought this car for 500$ from a guy that didn't know what he had. The car has never been wrecked and is in perfect shape. I just want to get the most out of my fac tune port cause i love the look, I also want a very noticeable lope. Im putting 4.10 gears in it. I want around a 2800 stall. Ive had so many pep tel me so many diff combos and i fig that this web site would fix my problem...
Old 11-04-2009, 09:40 PM
Trampus83's Avatar
Oh I forgot I have a 383 stroker kit for it also...
Old 11-05-2009, 11:20 PM
AutoRoc's Avatar
Does it run good now? I'm not a big fan of spending money on good parts and then topping them off with a stock TPI setup... It's like buying a a muscle car to tow a trailer... not very fun in ,my opinion. TPI makes torque, these mods make a TPI car worthwhile. Goodluck!
1. Mickey Thompson ET Street Radials(255/50/16)
2. 2600rpm torque converter
3. 75-100 shot of nitrous.
*A TPI car is useless if it doesn't hook up when you plant the GO pedal.
**The converter feels like a 50hp gain because it puts you AT the torque peak when your press said GO pedal.
***Nitrous speaks for itself. Instant 100hp/200ft-lbs of torque.
AutoRoc is offline
Old 11-06-2009, 08:21 AM
Trampus83's Avatar
I got it in jan of this year and it didn't run. It had been sitting sence 05 I got it home and had it running before the night was over. It always smoked so I fig I would just rebuild the engin. It ran great after i got the thing timed... i did the normal stuff to get it running again I pulled the motor and found it was bored 40 over the crank was turned 20*, The block didn't have a single ring grove or scratch and the carbon build up in the cylinders wiped right out... I think the guy put the wrong size rings in it... He was a real winner! The heads and block both had been reworked recently. It also has a roller cam with roller lifters, My buddy talked me into ordering the comp cam thumpr series cam 235/249 duration an 521/507 lifts. I am not going to stroke it any more trying to save money to spend else where. Am I on the right path and if so what heads do yal think would work best??? Thanks im kinda new at all this hot rod stuff ive always worked on motors with my dad and grandpa but it was just factory stuff this is my first build...
Old 11-07-2009, 01:38 PM
mdenz3's Avatar
Heads wont do you any good if the air can't get past the intake. The TPI intake is terrible for performance. Going to a LT1 intake converted for and distributor will yield more gains than heads.
mdenz3 is offline
Old 11-12-2009, 05:18 PM
rik89gta's Avatar
Seems to me like you've got much research to do. Do a search and look at the many proven combinations that work. A mismatched setup will leave you rather frustrated!
rik89gta is offline
Old 11-13-2009, 12:11 PM
ws6transam's Avatar
If you like the "look" of TPI, then you need to look at Scoggin-Dickey's website for their Vortec TPI intake manifold, plus a set of their Vortech cylinder heads. Then you need whatever camshaft Scoggin Dickey recommends for those heads. It'll probably be somewhere around 218 to 224 degrees of duration, with no more than .550" lift. It'll still have a lope to it, don't worry.
Rely on the experts who do this every day. Don't rely on your friend. A thumper cam with those specifications you quoted, if it's at .050" lift, will do nothing but sound radical, but it will be a dog off the line, and choked to death by the TPI before it even gets to it's peak powerband.
A 235/249 cam should be used ONLY with a single plane intake manifold capable of allowing for a 6500 - 6800 RPM operation: A Miniram, a converted LT1 intake manifold, or possibly a Stealthram. Either that, or forego EFI altogether, strap on a Victor 4BBL manifold, some well-ported aftermarket heads, a 3000 RPM stall converter, and go hit the dragstrip.
ws6transam is offline
Old 12-27-2009, 07:26 PM
1987IROC350's Avatar
I have the Scoggin crate Vortec TPI motor. They put the GMPP hot cam in it. It's 218 228 .525 .525 lift.
http://sdpc2000.com/details/scoggin-...nter/sd360vtpi
http://www.cis.udel.edu/~davis/z28/buildup/cam/
1987IROC350 is offline
Old 12-27-2009, 09:31 PM
ws6transam's Avatar
http://sdpc2000.com/details/gm-perfo...parts/12480033
How does it run and sound?
Old 12-28-2009, 07:27 PM
It runs very good and sound incredible. I'm having some trans issues right now to get thru. But a 1987 Trans Am GTA with the same motor ran low 13's on pass time. Ha ha. I figure I'll be in the low to mid 13's.
http://www.youtube.com/watch?v=t1eNVPr0pkg
EDIT:
Here is the GTA I was talking about. Turns out I video taped it on my cell phone. I posted it on Youtube.
http://www.youtube.com/watch?v=233b_edsvSg
CARiD
09-30-2015 05:44 AM
sleeperZ96BT
09-10-2015 08:01 AM
gonzo275rltw
09-07-2015 04:46 PM
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
Quick Reply: HELP!! 87 Iroc build
