EGR removal from TPI
Old 09-27-2004, 08:42 AM
  #16
MerF's Avatar
Re: EGR removal from TPI
But isn't my car metered by MAF? If the MAF isn't detecting the extra amount of air going through it, because it's coming from another source, then how can it properly meter the amount of fuel? The 02 (without being broadband) is less about metering and more about general failure of the engine (extreme rich/lean), but the engine could still be slightly off-kilter (enough to show up on the plugs) and the o2 not pick it up.
I'm speaking only from experience of tuning a single turbo Supra, which may be another world altogether, but that beast ran 8:1 AFR when I had a monumental boost leak in it, the o2 didn't lean anything out at all, because the MAF was metering huge amounts of air, the ECU was dumping huge amounts of fuel.
MerF is offline
Old 09-27-2004, 03:29 PM
  #17
aklim's Avatar
Well, in the program you write in a correction factor. Lets say you figure 300 cu ft of air coming in, you just figure on it while writing your program. Also, on it's own, the ECM has a window of correction too.
aklim is offline
Old 09-27-2004, 08:00 PM
  #18
MerF's Avatar
Not quite sure what you are saying there aklim...
MerF is offline
Old 12-22-2015, 02:49 PM
  #19
klowny1969's Avatar
^Video on how to delete an egr from a tpi engine detailed step by step..also checkout my channel and subscribe if you like
klowny1969 is offline
Smokn '94 Z
08-21-2002 03:55 AM
TrouserSnake
08-08-2002 06:17 PM
TrouserSnake
08-07-2002 12:43 PM
Smokn '94 Z
08-04-2002 06:11 PM
Smokn '94 Z
07-28-2002 02:38 AM
Quick Reply: EGR removal from TPI
