diverter valve for the heater core lines
Old 02-18-2009, 03:46 PM
pimpinphil's Avatar
hi,
i was going to delete this divereter vavle, but i was thinking. do i need this??? i know it bypasses the heater core. but is it actually needed for anything? my car still has air conditioning, its a 91 rs by the way.thanks alot
pimpinphil is offline
Old 02-18-2009, 07:04 PM
86camaro383's Avatar
why do you want delete it?
86camaro383 is offline
Old 02-18-2009, 08:37 PM
pimpinphil's Avatar
i just want to clean up the engine bay,and it looks like it had a vaccum line to it, but im not sure where it goes to. i just got this car,and it is a wiring mess. so im trying to clean everything up. also, it would just be 1 thing less to worry about.
Old 02-19-2009, 12:45 AM
quickchicken's Avatar
yes you need it. if you yank it you will have consistant heat in your car at all times. if you notice when driving you have air flow at your feet area, this is GM's "fresh air" system. if you delete the D valve it lets hot coolant consistantly flow.
quickchicken is offline
Old 02-19-2009, 08:29 AM
pimpinphil's Avatar
hi,
i thought it might do that. anyways, is there a vaccum line to it? it appears that way on top, and is it need to function something in it?where does it go to? so i can hook it back up,thanks alot.
Old 02-19-2009, 08:59 AM
the vac line is the hard plstic kind that comes out with the harness by the dizzy. there might be 2 lines. one goes to the intake and the other goes to the D valve.
Old 02-20-2009, 08:20 AM
pimpinphil's Avatar
thanks, ill try to find it, if i cant find that line, will just a vaccum line work off another source on the intake? thanks alot.
phil
Old 02-20-2009, 11:53 AM
you need a vac source from the motor on 1 line and the other line goes back out to the D valve. if your asking will any vac source work to supply vac to the HVAC controls, yes is the answer.
Old 02-20-2009, 03:39 PM
pimpinphil's Avatar
alright, thanks alot. i did find the lines, im not sure which is which, but i assume either will work. but anyways ill change them around, the guy i bought it off of had one going to the intake itself,and the other to the carb. "not sure why" but like i said, just trying to get this thing figured out,and get it right. anyways thanks again for all your help, its been great.
Old 02-21-2009, 09:13 AM
glad i could help. if your lines are lopped of or broken, small rubber vac line can be used to replace the tiny factory plastic lines.
as for which is which, generally the longer one is the one that goes to the D valve and the other goes to the source of vac unless yours haew been broken off. if ya need the fitting that goes on the D valve let me know, i have a few here.
Old 02-21-2009, 12:14 PM
pimpinphil's Avatar
i think i got her worked, again thanks alot for your time.
phil
alex5366
03-08-2015 11:32 AM
kksi
02-17-2015 10:41 PM
crazypurgatory
01-12-2015 10:45 PM
Britbilly
01-07-2015 08:49 PM
Black93lt1
11-21-2014 07:30 PM
Quick Reply: diverter valve for the heater core lines
